puting on a backrest is a pain
Old 04-06-2007 | 06:37 PM
06king's Avatar
06king
Default puting on a backrest is a pain
just came ups so i get it all together and go out side and i strip the last two bolts my the tail lights on my fatty. Crap looks like a drill and an easy out time now. and I'm out of beer. any one else have trouble with these thing or am i retarded?
Old 04-06-2007 | 06:41 PM
vertigo14's Avatar
vertigo14
Default RE: puting on a backrest is a pain
that sucks..
prob way too much beer to work on a 20k dollar bike
one helpful advice, made sure the tool you are useing fits correctly and always make sure its all the way seated before you start applying pressure.. and keeps fully seated..
Old 04-06-2007 | 06:42 PM
06king's Avatar
06king
the bad this is there was no beere involed at all no beer in the house
Old 04-06-2007 | 08:26 PM
loader's Avatar
loader
Which side is stripped, The TORX?
Old 04-06-2007 | 08:41 PM
06king's Avatar
06king
yes the torx
Old 04-06-2007 | 08:55 PM
tmitchellof PG's Avatar
tmitchellof PG
Which torx head bolts are by the tail light? I bought a set of torx bits from Sears, that seem to be good quality. When I removed the torx bolts from the fender struts, I had to use a cheater bar over the handle of my ratchet in order to break them loose. I have read that you will have problems with rounding out the heads of the bolts, if you use a cheap set of torx bits.
Tom
Old 04-06-2007 | 09:14 PM
NoVaThunder's Avatar
NoVaThunder
Also theyuse asize 45 torx not 40. I nearly rounded one of mine using wrong size. The 40 seemed like it fit and I didn't have a 45 at the time.
Old 04-07-2007 | 06:09 PM
texfatboy's Avatar
texfatboy
make sure you have good quality torx sockets. i wouldnt consider craftsmans tolerances on super tight fastners, if you use a quality torx socket of the correct size and it feels like its goingto round off. dip the end of your bit in valve lapping compound, the grit in the lapping compound will give that bit extra bite.i have actually removed rounded out torxs and allens with this tip. good luck, hope you dont have to put a drill on your bike....kerrry
Old 04-07-2007 | 06:17 PM
djkolp's Avatar
djkolp
ORIGINAL: 06king
Trying to decipher your posts. I think you meant to say "There's no longer any beer in the house."
[sm=alcoholic.gif]
Old 04-07-2007 | 06:29 PM
vertigo14's Avatar
vertigo14
ORIGINAL: texfatboy
I am not familiar with valve lapping compound... name brand? where one might find this product?
Quick Reply: puting on a backrest is a pain
