Electrical connection ?
Hi all: I am looking to add a pair of Cycle Sounds 3-inch handlebar speakers. I have an AUX circuit running up to my passing lamps and I am wondering if I can use that same circuit to power the amp. As far as I can tell the only load on AUX are the passing lamps which are LED and therefore not that much load. Cycle Sound says their amp uses 2-3 amps and the AUX circuit is good for 15 amps.
So, is this doable? Is it wise? Or is there another way to power the amp which is better for the bike? I do want the amp switched by the AUX circuit so maybe a relay is better?
Thanks a bunch, Chris.
I don't know what the aux passing lamps are? If they flash I would not utilize that wire for a power supply. I powered my J&M handle bar speakers directly from the battery posts with an inline fuse and switch. I fed some 14ga wire up under the fuel tank above the motor to the fork tree cover and tied the connections up behind the fork cover. This does not get any interference from the factory electronics, nor does it affect the factory stuff.
Actually it is not. When I put on may lamps, HD had a harness adaptor that plugged into the open AUX circuit plug under the tank. No more need to power off of the original design which indeed was tied to the headlight.
BTW, when you ran the wire, did you try to sneak the wires down the same tunnel as the factory wiring?
What kind of bike?on my 13 fatboy there is a plug under the front of the gas tank that plugs right into the amp wiring harness.
Robtarra39
2014-2023 Touring Models
14
03-29-2017 01:54 PM
