Burly, or Harley? Ape kit help
I have Burly Bars/Wire/Cable Kit. I'd have to say it's a high quality kit. Directions leave a bit to be desired. One tip, if your stick wires that you pull ut of your controls are long enough, tape the ends together and send them through the bars, then solder/pinch on your extensions. That would have saved me some serious time.
You pulled them through with no tape??? ouch... lol
Did the cables seem to run a bit big? I've heard complaints that the Burly kits usually run big...
Thanks for the feedback!
No, I had already put on the wire extensions which makes a bit of a bulge and are difficult to pull through, I still taped then ends and did the string/nut trick. I def had extra wire and probably a couple inches of extra clutch/throttle cables. Brake seemed to be dead on.
nashvegasmatt
02-06-2015 04:50 PM
