Floorboard opinions?
I have the wide band grips, passenger pegs, shifter, front Axel covers,and brake pad but still have the stock floorboard inserts. HD wants $200 for the matching floorboard inserts but I have been eyeing the Flame collection. For the $200 HD wants for the wide band inserts I could get the Flame inserts $95, pass pegs $65, shifters $15 each x 2, and the brake pad $32, and chrome frontaxle covers $29. I don't feel like jacking with the grips right now so I would wait till later to tackle these. My issue with the wide band inserts is at 80 mph I'm afraid my feet will want to slip off due to very little rubber on these. If you have the wide band floorboards how do they work at higher speeds and do the translate the motor vibrations any more than stock? What do you think looks the best on a silver Fat boy? Thanks!!!!
RE: Floorboard opinions?
Slip off??? Most defiantly at 80 or 85 my feet already want to slip off the floor boards from the wind. If I don't apply pressure my feet will come right off the side of the floorboards. I am watching a set of the wideband inserts on ebay so if they reach the reserve and can be had for $120 or so I will jump on them.
I have the narrow band collection all over (except for the grips which I discarded for the entire-chromed ones) and I have no such problem going 100mph. My engine is an Evolution 1340 "spine/wrist massager". So in your case that should be the less of your concerns...
I would not go for the flame collection because mud will eventually (I've seen it) scratch the chromed surface in the boards [:'(]
But as I always say if you have that itch... you will have to scratch...
Best regards.
ORIGINAL: Softtail Bob
Do you have any problem keeping the floorboards clean and shining? I know with the knurled areas on these collections you have to use a tooth brush to clean the dirt out of the little cracks. lol..
Mimo.
Hey there Softail Bob,
I have the nostalgic inserts one because I like the "Old Nostalgic look" and the rubber to chrome ratio is such there is no problems with scratching or cleaning.The rubber is fairly stiff and raised a good bit above the chrome, I have no contact with the chrome areas here are some pics and the rear footboards have the same inserts as does the brake pedal and shifter pegs all match.
