Forward Controls on an FL Fatboy
Old 04-06-2007, 05:26 PM
loader's Avatar
loader
loader is offline
Default RE: Forward Controls on an FL Fatboy
ORIGINAL: vertigo14
Just got a reply from Accutronix, Loader....
Accuronix said:
"That's a confusing question. The brake line "Tee" has a port in it for the stock brake light switch. If this guy did not put the stock brake light switch in this port I have no idea what he did. It may be possible that he did not use my brake line & just ran a solid line front to back with NO "Tee" in it."
So what did ya do Loader, if you dont mind me asking...
OK, ok.. I gotta tell everyone that Accutronix(Troy) swore that the FC106- Series would fit the 07 Fatboys.. and I had to send them a series ofpictures showing them that they would not indeed fit. (Pics below) Then they asked me to send back my controls for modifications. You could say I pioneered the movement.. But I didn't expectthem to be following HD every change.(New motor this year )Sooo The brake line they supplied(back then)did in no way fit the OEM position of the brake light switch. I'm slightly offended that anyone would suggest running a straight line from the MCylinder to the caliper.. All this being said I fabricated a brake line with two Goodridge lines andwent with one of these: a Banjo/brake light switch that can bolt directly to the MCylinder or Caliper(mines on the caliper) I had to lengthen the light switch wires heatshrink and give it a clean look. Won't find it in a HD bolt on accessroies catalog.. HA
They don't fit-----> See where the rear plate is butting up against the front primary mount.
Old 04-06-2007, 05:51 PM
vertigo14's Avatar
vertigo14
vertigo14 is offline
LOL,
Teach me to ask more questions before I splurg.. we will see tho, how long ago did you buy the FC kit?
Asking them now, see whats up!!
Old 04-06-2007, 06:00 PM
RoyBoy2's Avatar
RoyBoy2
RoyBoy2 is offline
ORIGINAL: J
I have Accutronix 3" extended controls on my 04 Fatty. I installed them myself before I even rode the bike. The only prob I had was breaking the floorboard bolts loose, I needed a torch to heat them up. The brake line's easy, just measure and get the right one. Good luck.
I'm assuming they lock-tite those bolts?
Old 04-06-2007, 06:05 PM
vertigo14's Avatar
vertigo14
Hey Royboy make sure you ask the peeps who make the FC you may get if the extended version will hit the front fender. Accutronix did say their extended would hit my 07 fattys front fender. And eheh their heel/toe FC controls wouldn't work on a Softail.. Sigh :P
Lets try to keep our R&D minimum, we don't get paid to R&D !!
If I knew all the questions..I'd have all the answers already!!
Old 04-06-2007, 06:10 PM
RoyBoy2's Avatar
RoyBoy2
RoyBoy2 is offline
ORIGINAL: vertigo14
True enough, I'm thinkin a spacer might come in handy at this point, enough to clear the fender. That is, if one was to go with the ext. version.
Old 04-06-2007, 08:27 PM
loader's Avatar
loader
loader is offline
Hey Vert,
Did you order the Accutronix brake line?
Old 04-06-2007, 09:33 PM
vertigo14's Avatar
vertigo14
Yea Loader I did, off to see a movie...The Grindhouse
The Russel Brake Hose.. Stainless Steel... 99 F'n dollars.
And I had to buya whole new kickstand assembly.. I think their Illusion Line... not just the mount.
Old 04-11-2007, 07:53 PM
vertigo14's Avatar
vertigo14
The brake line that I got from Accutronix isn't gonna fit my 07 fatty...
I gotta come up with something.. any help on this?
(not very knowledgeable on brake lines(yet hehe))
I managed to put the old one off tho!! in one piece and nothing bent(pretty good for a hard tube line)
I should maybe try to use the old one... and add a piece? or section..
So right now I have the FC brake on (with out brake line) pfft its just back brakes LOL and Ill put on the FC shift tomorrow(or tonight) and kickstand.
Old 04-12-2007, 02:56 PM
loader's Avatar
loader
loader is offline
I tried to tell ya. As stated above there are no direct replacements for 07 fatties...
You didn't like what I did with the Banjo switch?
Old 04-12-2007, 03:23 PM
bikeknight's Avatar
bikeknight
bikeknight is offline
Nice Fat, Loader!
I have a black 07 and not sure whether to put any dough into or just sell it. Yours makes me think it may actually be possible to makemine look good. Haven't seen anything inspiring enough til now. Any pics from the side?
Steve
Quick Reply: Forward Controls on an FL Fatboy
