How come my oil dip stick launches when I start?
If it doesn't puke oil with the dip stick popping out, I would suspect the clogged oil breather....
Received 49,818 Likes
After looking at it, I think this is it.. its really loose.. an O ring is a fantasic cheap *** idea.. thanks guys.
I had the same problem with my Shovelhead when the rubber shrank up and caused the dipstick to get loose in the oil tank. Here's how I fixed it. I cut a short piece of copper water line and pushed it up inside the rubber stopper. It now fits tightly in the tank and doesn't pop out when starting the bike. Not sure if the stopper is the same size on your bike or not, but it may be worth looking into. Cheap and easy fix.
