Batwing on a Heritage
Getting tired of getting my *** kicked on my Heritage at 70+. Question is will a batwing significantly reduce the wind blast making cruising at hiway speeds more comfortable?
Currently I have a Memphis '21 windshield which helps but most of the wind that is bothersome is on my legs. Looking for solutions.
I have some Chilhowee Leather soft lowers I use in winter. They do help some with wind and are of excellent quality but you are on a motorcycle so wind will always be an issue especially at highway speeds.
Have a look at these.
http://www.leatherpros.com/website1_006.htm
X2. I have fork mounted lowers on my 2011 Heritage. I have no updraft under my helmet. There is a good air pocket behind the stock Heritage windshield and very comfortable. With regard to a Batwing on a Heritage, it is not for me. I feel the Heritage is a bike that has tradition that goes with it and the bike should look "traditional". That's only my opinion.
They certainly do restrict the air flow to the legs, but that also means they restrict air flow to the engine.
If I'm not mistaken the instructions state not to use them above 50 degrees due limitation of air flow needed for engine cooling.
The bike does run hotter with the lowers on so you might not want to go that route.
You know that just because the speed limit is 70 that doesn't mean you have to ride at 70.
55 mph will lessen the wind and you will still get to where you're going.
OK perhaps the 55 mph comment was a bit of a smartass remark, but that doesn't make it untrue.
The Wife and I go out of our way to travel side roads partly because we don't like the wind at highway speeds but also the scenery is so much better.
Life is too short to be in such a hurry!!!!
BatWing helps everywhere except the legs, however wind-deflectors do help some. I have in the pass and others I know wear their leather chaps no matter the weather and that does help! Once I got caught in a grasshopper invasion and after that I wore my chaps everywhere, but now back with jeans only. But about time to go back. Real salts wear them.....because they have already been down. Not IF, but when...so be ready!
