Air cleaner cover size??
I have a stage 1 air cleaner on my 2012 fatboy lo but it's under the stock football cover. Before I decide to chop that one up, my buddy works at a metal fab shop and was asking me the dimensions for a cover that just cover the front and the rubber on it.. I think I remeber measuring about 5 1/4" diameter to cover just the front and a 3/8" hole centered for the bolt.. Can anyone confirm these for me. So I can get them to my buddy ASAP.
I dont' have the actual dimensions but HD sells an air cleaner trim ring #29328-99 that fits on the Stage 1 air cleaner (it's meant to in the center of the stock foot ball). I just replace my stage 1 football with an Arlen Ness Big Sucker and that trim ring fit perfectly over both the HD filter or the Arlen Ness product. The filter element is exposed but the side of the filter that faces out is covered by the trim ring. You can probably google the dimensions. I've attached a photo of the football with the trim ring on it so you can see what I'm taking about. (Incidentally, if you really want to go on the cheap a CD or DVD will cover it also).
