Better passenger seat for Breakout?
The factory passenger seta on the Breakout is certainly not a "long distance seat"!
My wife wants to rider as a passenger, but the seat's small size and thinness makes her reluctant to talk about any rider longer than say 20 miles.
I talked to a motorcycle seat expert today about adding gel to the rider's seat and the passenger seat, and then recovering both seats plus the sissy bar pad with a nice exotic set of covers.
He pointed out that the passenger seta really needs to be wider to be comfortable, even with the gel added, and said that his work would be far less costly if I could find another Harley passenger seat that has the same two mounting hooks on the front and the same mounting bolt hole location on the rear, but is wider. Then, he could use that seat, gel it, reshape the foam appropriately, and recover to match the new covers on the rider seat and the sissy bar.
I know I could simply buy a Danny Gray or other brand name seat, but I had to go to a "Reach" version of the HD RIDER seat to get fully comfortable on the bike, and today I had the seat guy add gel to it and also a bit more back support, so it is perfect for me, and no commercial seat is going to match that.
So, does anyone know, is there another HD passenger seat that has the same mount types and points, but is wider?
Jim G
Jim G
I'm assuming here...But the sundowner passenger pillion looks like it will fit. The only problem I foresee is that it might not butt up against the rider's seat if the profiles are different...but if you are having the foam reshaped and then re-covered...I don't think it would be an issue.
The one I saw said it was specifically for the breakout...and since the mounting hole and studs are attached to the bike and not the rider's seat...I know it will fit. It might not butt up against the rider seat, but like I said...if you are getting them reshaped, it shouldn't be a problem.
Thanks to both of you! The Sundowner passenger seat should make an excellent base for Steelhorse Bob to work with. He can easily reshape that front end to cover the gap!
Now, I just need to find a used one somewhere so I need not spend $149 for a brand new one that Bob will immediately cut up!
Jim G
Jim G
I went through this somewhat. My girl calls the SD the marshmallow seat, loves the comfort.
I tried similar surgery to the pillon but not with gel, just different densities using a guy really well known in Tulsa for his bike seat magic. Better, but not good enough.
I bought a new SD pillon and really this fixed all but there was an aesthetic gap to the stock solo seat. Eventually I bought a used SD solo and the SD's are on the bike now. I actually prefer the SD solo seat but life is about compromise.
I've wondered how much shotguns would help "her" comfort. IMHO, the stock pillon is way better aesthetically, I'll just say I'm well rewarded for keeping her comfy
Now my OL is quite happy
proridermp.com
At proridermp.com should have it, if you don’t see on their models just chat them, because for some reason they don’t show all the inventory online, but they always have the seat that the people wants, they are expert and always ahead the others
Poley Paul (08-29-2023)
Hooper
11-08-2005 01:42 PM
