Synthetic Oil Choice
#31
RE: Synthetic Oil Choice
ORIGINAL: bobros
Top 3 synthetics are probabally Amsoil, Mobile 1, and Redline.
Group 1
Group 2
Group 3-- Mobile 1
Group 4-- Amsoil
Group 5-- Redline
If you do some research, you will find that Group 1 through 3 are not TRUE synthetics, they are dyno oils with additives that allow the manufacturer to call them syn's. Group4 &5 are the only true synthetics because they start with synthetic base stock.
#32
#34
I use xtra virgin olive oil lol.It dont matter wut oil you use you still have to drain and replace it all engines displace moisture so dont matter syn or regular oil.My dealer told me to put wut came in it and change it regular atintervals syn will break down with moisture anyway.As far as heat if my bike gets that hot wich it hasent ill pull right into the closest watering hole and get a bottle of suds at stare at my ride and blow it kisses wile it cools down lol
#35
#37
i must correct my post. screaming eagle was at .7 on the wear test. Mobil 1 was .65. Amsoil .4. Please forgive me, just going by memory and my memory is old.
http://www.smartsynthetics.com/produ...engine-oil.htm
#38
Im having my 5000, service done on Thur. tha 5th. I requested Amsoil for the engine and my provider says they useBelray for the other holes. Don't know what the advantage of mixing is. I hear Amsoil allows the engine to run cooler. They say they've had happy riders using this method. Any suggestions? I have 2 days
#39
i'm running amsoil sever gear in the trany. I think it smooths out the shifting a little, might just be me. I will say that on my trip to bike week, my oil ran between 5 and8 degrees cooler than harleys syn3 (previous oil in bike before I researched amsoil)and the days temps were in the 50's' and 60's. Should improve as days get hotter.
Iron lHorse
03-21-2010 10:11 AM
