How important is the compensator sprocket?
#71
Jim G
#72
#73
The instructions for The Game Changer are available on line, and I found and read them. Apparently, some HD models did not get the Screamin' Eagle version of the compensator until the 2011 model year, because the instrucitons say that if your bike is 2011 or newer, you're good to go.
Jim G
Jim G
The photo shows the "piggyback" tensioner piece very nicely. The instructitons warn you that once you orce that piggyback tensioner piece onto the factory tensioner, you cannot remove it without destroying the factory tensioner. So, make SURE you want to do this beforehand!
Jim G
Jim G
I wasn't real clear if the 11 and up bikes were built with an updated compensator or actually had the same part they are selling through the SE catalog.
Thanks guys
#74
Jim G
#75
Except for a couple pages in the middle, arguing over dyno numbers/affects, this has some posts from guys with the primo game changer installed.....
http://harleytechtalk.org/htt/index....c,84784.0.html
#76
#77
Jim G
#78
I'm pretty close to getting one of these for my bagger.... I'm sure I will eventually, it's just in line with a bunch of stuff I'd like to get...
#79
Part numbers: P/N 1066-0050 – 2007-2013 Big Twins, P/N 1066-0051 – 2014 & Later Big Twins
Came across this last night
http://www.ebay.com/itm/231743333849...3D351423126014
I ordered one, then I started checking part numbers Ronnie's Microfiche has my 2011 Fat Boy Lo (FLSTFB) with the part number 40296-06A
http://partsfinder.onlinemicrofiche....ND%20SPROCKETS
The SE compensator on Harley's website is listed as 40100061, but it looks like this assembly comes with a rotor too
http://www.harley-davidson.com/store...PAC+PDP+Bottom
They look to be of the same design, if the pictures are close to being accurate, and I'm thinking the part number differences are due to the SE assembly includes the rotor while the stock part number is just the compensator.
