Breakout footpeg restrictions per HD catalog
Looking at the HD "Diamond" foot pegs in both black and chrome, I discovered something pretty interesting: The Breakout, and a number of other HD models are specifically excluded when HD lists the compatibility's by model, unless you buy pn 50500035 which has a "styled wear peg" ("feeler") attached.
The restriction includes all Sportsters, the Rockers, and 2011 and later FX and FXSB (Breakout).
Since all Harleys appear to use identical male/female foot peg mounts, it isn't a mounting incompatibility. So, it occurred to me, is it that the restricted models all have perhaps low ground clearance? In other words, does HD want you using these pegs that come with "feeler" because they want the feelers to hit before the primary cases or exhausts do?
This would make sense from a liability perspective, since without the feelers, once you hit the cases or exhausts, you are basically going to go down.
Thoughts?
Jim G
Thoughts?
Jim G
Interesting point. I wondered about this since the slipstream pegs on the CVO Breakout don't come with wear pegs. I actually put the same offset from the CVO on my bike with the Slipstream pegs (without the wear pegs) and I definitely scrape sometimes. It's mostly the heel of my boots and sometime the pegs themselves, but I've never touched the primary or exhaust to the ground.
Thoughts?
Jim G
Thoughts?
Jim G
I haven't looked closely at the Breakout's pegs, but since it's built on a Rocker leftover frame, I'd guess they are the same.
Any male mount peg meant for a HD would fit is my guess.
Sounds the same as our rockers. Any hd peg will work, but will be in a slightly diff. position. There is about a half in jog in the stock rocker pegs to give more room. It's only a half inch and I changed mine years ago and it took me 30 seconds to get used to it...not an issue unless the half inch bothers you...half inch is not much when your talking about pegs...other things, could be important...LOL.
Ride safe.
Ride safe.
Jim G
My current "pegs" are higher than stock as well as slightly closer to the bike, no issues here.
Your higher and tucked in pegs are of course a good solution to not dragging the pegs, but they take away your "warning" that you are near the edge.
You're probably a very good rider 24V, but your posting encourages others to try something that THEY might not be as successful executing as you are.
Jim G
Breakout73 (05-02-2019)
