FXSB Breakout with FXSBSE CVO handlebar
#51
Hi 89Speedy, I am thinking of buying a 2015 Breakout, and am interested in the bars you have. Can you give me the specs? Rise, pull back, tip to tip width, etc? Did you also replace the stock riser?
I was curious if you have ever ridden a Heritage Softail? While test driving a few bikes I really like the riding posture of the Heritage, but MUCH prefer the look of the Breakout. If you have ridden one I was curious if you think this bar gets you close to that riding posture.
Thanks in advance.
Thanks in advance.
#52
What are the bars you have no your Breakout now? The ones in the pictures?
#53
Does anyone know the part # for those bars? I just bought a 2016 Breakout and the drag bars are a pain to ride for me...4 back surgeries so leaning forward isn't comfortable....My son also has a 16 Breakout and has the Softtail reach bars and they feel 10x better riding....The bars on his is # 55800188...Both bikes have abs...HD quoted me $287 for lower brake line and 73 for the upper to be able to swap bars...I forgot what they quoted the clutch cable at...Then 6 hours labor on top of that...I could prob swap them in the garage in 2 including beers...
#55
Thanks Notch...those are def the ones Im looking at...HD quoted me like 1100 to have those installed, not including the bars! Said I would need new upper and lower brakes lines, clutch cable and throttle twist sensor....went to another Harley shop and that said I would maybe need just a new upper brake line at most...I also looked at Drag Specialties bars part # 0601-1519....they look to be the exact same bars...A friend had them installed at HD of Lake Charles for $690 including the bars...
