This is a new one.....
I bought my '07 Standard last late July. Not long after I bought it every once in a while I would get a little oil leak on the primary side right behind the primary. I could never figure it out until one day I seen it dripping from the left side back corner of the oil tank. I ran my finger under there and sure enough fresh oil. I could never figure out where it was coming from. All the lines were okay and tight with now oil around them. It would happen just every once in a while also.
On saturday I rode it out to the dealer to have them put my chrome front end on. Guy called me later in the day to say it was done but informed me that it had leaked a good spot of oil. They traced it to the start and stop spot on the underside of the oil tank on the weld. Said it was a small area where it didn't get finished completely. That spot was on the right side of the bike just below the dipstick entry. Now it was leaking badly. Not like before where it would do it once in a while. It must of been a small leak and would run all the way to the otherside when on the jiffy stand.
I was always going to take it to the dealer to have them check it out but could never get it to happen consistent enough... Couple of times I read on here where some of you would experience "the leak" but atributed it to overfill which is what I thought it might be. I wasn't sure if there was a vent tube back there under the tank or not. Never took the time to look or at the manual. Then I got to thinking... you guys must mean the tubes on the 1stage... but that would mean it would run down the side of the engine.
So anyway... getting a new oil tank... under warranty. So if any of you find an unusual leak at the rear of the bike.... might check the weld on the early 07's.
RE: This is a new one.....
Glad they foundit and are taking care of it. What some of us have experienced is oil that drips out of the vent hose that runs behind the oil tank and in front of the mud guard on the rear tire. For me it is only every once in a while and only about a dime-size or smaller spot. I had mine into two different dealers and they found no leaks anywhere. From reading on here it seems this is just a problem that some people have if the oil level is filled over a certain point. I keep my oil level at about 70% of the operating range on the FULL HOT marker. Shovelhead Bob reccomended this to me, and it has seemed to work. I still get the spot now and again, but that's b/c the oil level is going to rise the hotter the oil gets, so depending on temp.my oil level may be at 65% or 75%.
I have an '07 softail custom and believe it or not, I have an oil leak at the neck bearings. They said it is from when they assemble the front end. I have 2700 miles on it and it is still leaking. Well, how much oil did they put in there? It's driving me crazy. I put about 200 miles on it yesterday and I had oil all up onto my tank around the gas gauge and back down.
ORIGINAL: TheGeek
Cheers!
[sm=icon_rock.gif][sm=icon_rock.gif][sm=icon_rock.gif]
