Fat front wheel/tire on an '07 Night Train
Old 04-05-2014, 11:32 AM
ChromeJunkie's Avatar
ChromeJunkie
ChromeJunkie is online now
Received 4,229 Likes on 1,844 Posts
Originally Posted by jreichart
https://www.google.com/search?q=16%22+harley+front+fenders&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-USfficial&client=firefox-a&channel=sb
A fatboy fender fits right up to FX front ends. At least on mine it does. The custom ones will fit anything as they are undrilled and probably the best bet to get a nice tight fender/tire clearance.
I would have never thought that a fender from an FL softail would have fit an FX fork. I just happen to have both a Fatboy and a Heritage front fender in my shop. Thanks for the info.
Old 04-06-2014, 06:18 PM
olongapo1's Avatar
olongapo1
olongapo1 is offline
Attached are Mock-Up photos of an experiment I performed on my 03 Train. The rim is stock, off an 02 Heritage with a 16 x 140 series tire mounted on it. The fender is from a like-era Fatboy. Everything lined up and bolted on nicely without the need for fabrication work.
My plan was to trim the fender down however I didn't follow through with the modification due to erratic handling characteristics of the 140 series tire.
Attached Thumbnails Fat front wheel/tire on an '07 Night Train-img_0094.jpg   Fat front wheel/tire on an '07 Night Train-img_0102.jpg   Fat front wheel/tire on an '07 Night Train-img_0103.jpg
Old 04-06-2014, 07:16 PM
jreichart's Avatar
jreichart
jreichart is offline
Since you mentioned the change in handling, I will chime in on that as well. When I initially did the swap, the front end became heavy, with noticeably more wheel flop during slow speed cornering. This is because of the difference in wheel diameter. The 16" with a 150 tire drops the front end about 3/4". Doesn't sound like much, but it's enough to change the trail and affect handling. I just installed bolts and dropped the rear 3/4" to compensate. Handled just like stock after that.
joshag
02-19-2012 02:33 AM
dbrown5
Softail Parts
01-29-2012 10:09 PM
Cav Cop
Wheels/Tires
06-19-2011 10:03 PM
TheLaw
Wheels/Tires
04-24-2011 05:19 PM
saintslax11
06-11-2007 11:36 PM
Quick Reply: Fat front wheel/tire on an '07 Night Train
