ONE Breakout mirror solution
A number of Breakout owners have complained that they cannot see the road behind them through the stock mirrors. There is a solution.
First, the problem is not "really" the stock mirrors. It is the short overall length of the Breakout "drag bar" handlebar - just 33 inches.
This "narrow" bar length results in you getting a really nice view of your arms and shoulders, even with the stock mirrors that work just fine on many other HD models.
I spent some quality time at the local HD shop, measuring a bunch of available mirrors, but looking specifically for 2 attributes:
- a significantly longer distance from the center of the stem mounting bolt to the outside tip of the mirror. The stock mirrors measurement is about 6 1/4 inches, so I was looking for mirrors with a significantly longer measurement
- an overall height, from base of mirror stem to topmost edge of mirror, that was as low as possible, since the Breakout is all about "low", so to look right the mirrors should be pretty "slammed".
I found a pair of mirrors that fit the bill perfectly: The HD "Tribal" mirrors, part no. 92398-09. These mirrors have a stem bolt to outside tip of mirror that is about 8 inches - significantly more than the stock 6 1/4 inches. Plus, they are "convex" (show a wider area than flat mirror glass), PLUS they are truly "slammed" in height.
Here are photos:
Here is a photo with the stock mirrors, for comparison:
These new mirrors work GREAT. I can see everything right in the lane right behind me, in either mirror, and of course everything to either side. And by the way, I wear a size XL jacket, so it's not like I am tiny.
And, as you can see, the combination of low overall height, "slit" type shape, and the black color, really changes the appearance of the bike. Much more sinister.
A successful minor change.
Jim G
Here are photos:
Jim G
micro and i had MAJOR issues with the exact same problem. within a week or so of owning the bike, we got these:
looooove these mirrors. adjustable at two points, so there's no problem getting them into a good spot. doesn't hurt that they look fantastic on the bike either.
Amazon.com: Magazi mirror Venom black iron gray motorcycle trike sportster bobber cruiser street naked road bike: Automotive
B.K. (02-13-2018)
Plus, I'm pretty sure the mirrors, if mounted UNDER the bars, would hit the tank when turning. The Breakout handlebar is VERY low.
Jim G
No, on the Breakout they cannot be flipped because the turn signals are fastened to the bottom of the mirror shaft, and the signals will only fit in that location (they have a tab on them to align them correctly).
Jim G
Jim G
But, yes they will hit the tank with stock bars/risers. You may be able to swivel them way forward to clear, but then I don't think you could angle the mirror back enough to be able to see correctly.
BTW, I love the Tribals on a Breakout. I would still be running them if they had enough adjustment for me.
