Cable Length for Gangster 16's????
Old 03-27-2014, 12:42 PM
CountryD's Avatar
CountryD
CountryD is offline
Default Cable Length for Gangster 16's????
Going from 18 inch gangsters to 16's, need to know cable lengths before I order from Magnum. I had 18s on my previous bike, but going for more comfort this time around
My 18s, I think I used +10s, but I cant remember exactly, and I would go measure but the bike doesnt come until MONDAY.
Anyone with 16 inch gangster Apes that knows exact lengths of cables that I need?
Thanks fellas
Old 03-28-2014, 08:56 AM
Malingerer's Avatar
Malingerer
Malingerer is offline
Hey brotha welcome back to the game. I have the 16 " gangsters but they are the Full 1.25 " version. Im sure you are gonna run the 1.50 bars which are about 6" wider.
I went + 10 all around. Dr Vtwin recommended +8 (when they were around) but you cant return them so i did not want to get stuck. So I played it safe.
That being said, I have some extra cable length and think the + 8 would have been fine.
I will post the best pics I have of it. The + 10 s still look fine though.
I would say with the 1.50 bars if you want a tight fit
go with + 8 ,it may be a little risky though. If you want to play it safe go with the +10s. They will still look good and you wont have extra cable flopping all around if you route them nice and neat and use some cable clamps like I did.
Hope this helps.
Attached Thumbnails Cable Length for Gangster 16's????-dsc02398.jpg   Cable Length for Gangster 16's????-dsc02396.jpg   Cable Length for Gangster 16's????-dsc02399.jpg   Cable Length for Gangster 16's????-dsc02401.jpg   Cable Length for Gangster 16's????-dsc02409.jpg
Old 03-28-2014, 09:04 AM
Malingerer's Avatar
Malingerer
A few more
Attached Thumbnails Cable Length for Gangster 16's????-dsc02407.jpg   Cable Length for Gangster 16's????-dsc02400.jpg
Old 03-28-2014, 10:22 AM
Zambo5000's Avatar
Zambo5000
Zambo5000 is offline
I just installed 14" 1.25 gangsters. I went +8 on all cables. (Picture coming soon) I like the fit of the throttle/idle cables, but I think I could have got away with +6 on the brake and clutch cables to tight things up a bit.
I went to the HD parts catalog and got my cable measurements based off their 16" ape measurements because I read couple places that Carlini's run taller than advertised. The 1.25" run pretty true to size. I assume the 1.50" may run a bit tall because on the added girth. I'm not sure the exact measurements but they run a lot wide. 4-6" I think
Old 03-28-2014, 10:25 AM
Zambo5000's Avatar
Zambo5000
I just installed 14" 1.25 gangsters. I went with Magnum Shielding too, +8 on all cables. (Picture coming soon) I like the fit of the throttle/idle cables, but I think I could have got away with +6 on the brake and clutch cables to tight things up a bit.
I went to the HD parts catalog and got my cable measurements based off their 16" ape measurements because I read couple places that Carlini's run taller than advertised. I find the 1.25" run pretty true to size.
I assume the 1.50" may run a bit tall because on the added girth. I'm not sure the exact measurements but they run a lot wider. 4-6" I think
Old 03-28-2014, 11:05 AM
yzergod's Avatar
yzergod
yzergod is offline
Why change the cables? You're only going down by 2". I had +10 on my 16" Wild1 Chubbys. If I was buying them, I'd go +12 since the 16" Carlini's are about 1.5" taller than the Wild1s. HTH!.
Old 03-28-2014, 11:23 AM
Malingerer's Avatar
Malingerer
He is getting a new bike, his old bike with the 18's was sold a while ago.
Old 03-28-2014, 11:44 AM
CountryD's Avatar
CountryD
CountryD is offline
Yeah what tommy said, sold bike got a new one.
Going with 16s this time. Guess I'm gonna have to wait until Monday when the bike gets delivered to do some measuring. Want them perfect.
Tommy, what bar clamps did you use?
Old 03-28-2014, 12:07 PM
ejslim's Avatar
ejslim
ejslim is offline
Malingerer, you have one sexy bike!
Old 03-28-2014, 01:40 PM
Fatboy USMC's Avatar
Fatboy USMC
Fatboy USMC is offline
Default Drag specialties
I know if you look in the DS catalog that they have a table chart in there for cable lengths, I used it figure mine out and I'm running 16" Gangster Apes
Quick Reply: Cable Length for Gangster 16's????
