Rear Turn Signal Relocation on Fatty 07
RE: Rear Turn Signal Relocation on Fatty 07
Ended up getting a HD converter that only lights up the turn signals when the brake is applied. I get slightly annoyed at running lights when I am following them, so decided not to go with that function. Kit was only the converter and not the red lenses nor the mounts and was 39.99.
Put that on and a plug for heated wear heh.. not that I need it in spring/summer/fall but it's good to have..besides I don't like messing with the battery. Already had a charging harness so.. I am set
