How to put the HD digital speedo into setup mode??
I had mine installed at the dealer, and I didn't get the instructions. I've seen a Youtube video for the larger one, but I have 70900274- and it doesn't seem to go into setup mode by holding the trip button, and turning to ACCY. If I hold in trip, and turn all the way to ON, it seems to go into diag mode- but I want to adjust some of the color settings-
Any one with one of these that can tell me the buttons to push, I'd greatly appreciate it (or a link to a manual).
Thanks for the link. Apparently it is the same procedure as the other model- but for some reason, mine will not go into setup mode when pressing "trip" and turning to ACCY. The manual says something about possibly having a bent pin, or loose connection if this occurs, but I find it hard to believe that is the case. Everything else with it works perfectly- but who knows...
Only just joined and seen this post but if anyone still has this issue I had the same on a 2017 Breakout after installing a new digital speedo. The instructions for the speedo of how to get the bike into setup mode are wrong.
if you have a keyless ignition (not sure about others) you have to put the bike in accessory mode as explained in the bike user manual, I was then able to access all the functions of the speedo and alter to my needs.
Very quickly, 'accessory'mode i believe from memory was with the ignition off but the key fob close to the bike as if you were going to start up, press and hold the mode/trip button on the left hand grip, the display should light up, now press and hold both indicators/turn signals, the speedo will then go into setup mode.
Few days back installed speedo 2010 Roadking
and can’t get it to setup mode to change colours, everything else works fine.
have checked all connections, pins etc
pressing trip and then turn to acc, speedo goes to diagnostics mode
ignition and acc both does same.
local dealers answer was ”read the manual”
wperk903 (08-26-2023)
I had an electrical accessory hooked up to my 2010 Fatboy and that speedo wouldn't go into setup mode with the accessory hooked up to the wire I had it hooked up to. Changed to another wire,speedo went into setup mode.
razehog
06-22-2007 01:46 AM
