I am new to harleys and didn't see any posts about older exhaust on newer bikes. I have a set of V&H Long shots off a 2003 softail. Will they fit on a 2014 Breakout?
If they don't directly fit, can you modify?
Thanks for your time.
Chris
If you try to mock them up to the bike...mounting points and angles probably won't work. Better off getting a custom exhaust manufacturer/builder bend you a similar exhaust to your V&H LS's...
I would think they will work. You may have to tweak things a little, but it should be real close. Also, you will need adapters that step the oxygen sensors down from 18mm to 12mm.
