Belt and pulley
Belt and pulley
Correct me if I am wrong. I believe my rear pulley is a 66 tooth 07 nightrain. I was looking at switching to a 70 tooth that matches the rim I am gonna use, will the factory belt still fit with the 70 tooth pulley? And by switching to a 70 tooth pulley that will numericaly raise my drive ratio correct? So I would be a lil quicker off the line and would be few hundred rpm higher than normal when crusing?
