09 Rocker LED tail lights
I am looking for the wiring diagram for my bike because I bought some new LED lights with break and blinker and can not get them to work so far. I could use some help.
The ones I bought are 3 wire but the ones I took off are 4 wire. I can get them working if i touch the driving light to the one ground (negative) and then i can get the indicator working if i touch the indicator wire and the other (negative). But when I connect them together as a common ground the blinker dose not work. i Tried running a cable to the battery negative on the battery and the break light works again but not the blinker at all.
Thanks for any help that can be provided.
Been there...the stock ones are junk, leak water...I had 2 sets fail under warranty...Get the adaptor like folks said. Get a FACTORY manual, it's well worth it!!! It has great detail and ALL of the schematic drawings are included, even the electrical. Only 60 bucks on HD website, saw it the other day. One thing that HD makes that IS worth the price...LOL. Good luck.
I use these guys for all my LED needs, if you have questions they have the answers. You require a signal stabilizer/ turn modulator. Agreed a manual is a must, the info in there is invaluable.
www.chromeglow.com
www.chromeglow.com
Wray67
08-28-2015 01:21 AM
