No front fender?
No front fender?
Just ordered a 16" front wheel from a slim, for my blackline. Not sure if anyother fenders will bolt right on (from a slim possibly)? So, I was thinking about running no front fender and using a RSD fork brace. Any thoughts or input? How bad is water in the face during rain/wet roads, with no fender? Any input is appreciated.
wipers
If you ride in the rain you wont be happy. I was painting my front fender after a bit of repair and the boys were going for a ride so "I don't need no stinking fender" and went with. Once over the pass the weather turned wet and I was riding hanging off the side with a rooster tail of water shooting over my shoulder. The rain quit and I dried out but coming back home some sand had washed across the road. Then I was eating sand. They look cool without but the protection they offer I won't be without.
A fatboy fender might fit, and a 150 tire will just fit under it. I have run with no fender for a couple seasons now and the only issue has been rain. The tire throws up a significant rooster tail that hits square between the eyes. Leaning to one side helps a bit, and I tied a bandana between the forks just above the tire and it helps a little as well. Still lots of water in the face, I just deal with it and try to avoid riding in the rain whenever possible. No real need for a fork brace unless you like the looks of it.
Not sure of the blackline front end dimensions, but I put a fatboy fender on my FX front without any issues. IIRC, the FL and FX front ends share all the same dimensions, the only difference is the extra trim and tube length on the FL's?
