Removing steering bearing cups from Deuce
Old 01-27-2014 | 01:22 PM
JoeBye's Avatar
JoeBye
Default Removing steering bearing cups from Deuce
I desperately need ideas as to how to get cups out of the frame neck. The problem is on the Deuce (may be the same on others) is the there is no lip maybe 1/16 of inch to get a hold of. I tried to get several chisels punches and such to grip what little lip there is with no luck. I have read on the web where some have welded a bead on the inter part of the cup and they practically dropped out. Not a real option for me I have no welder and with no front wheel on the bike I can’t haul it to a welder. Before I take a dremel to it I was hoping someone on here has a better idea.
Old 01-27-2014 | 02:03 PM
Andy-Deuce's Avatar
Andy-Deuce
I used one of these on my deuce worked like a charm
http://www.ebay.co.uk/itm/WHEEL-STEE...item2eb3e690c6
Old 01-27-2014 | 02:31 PM
JoeBye's Avatar
JoeBye
Thanks for the info.
I looked at one before and wasn't sure if it was long enough to reach the lip of the cups. I never could find dimensions on it. I assume you Just put it in the neck expand it and then drive it with a hammer. About how long is it from the threaded bar to the flange that would catch the lip on the cups?
Old 01-27-2014 | 02:44 PM
Andy-Deuce's Avatar
Andy-Deuce
I have not got it nearby to give you a size, but believe me it works no problem in a deuce, buy one with confidence.
Old 01-27-2014 | 02:53 PM
JoeBye's Avatar
JoeBye
Thanks.. I am placing an order for one.
Old 02-12-2014 | 03:59 PM
JoeBye's Avatar
JoeBye
I am back to square one. The tool ordered is for the race only it will not fit down into the cups. I still need ideas for getting the cups out. It’s going to be in the 50s here this weekend and I hope to get in some garage time.
Old 02-12-2014 | 04:09 PM
Snowyone's Avatar
Snowyone
Default bearing
Well the welder works best but how about a slide hammer with a three finger jaw? Just make sure it will get small enough to fit in the cup. You can usually rent them. I've never actually used them because I have a welder and it's easier but might be worth a try.
Old 02-12-2014 | 08:53 PM
Ash16's Avatar
Ash16
I picked up a Jim's Tools neck bearing removal tool off of ebay when I did mine on my Train. It's three different parts that you have to get. These are the parts. Kind of expensive but made short work of mine.
http://www.phatperformanceparts.com/ProductDetails.asp?ProductCode=JIMS%2DSTEERING%2DT OOL&CartID=
Village Idiot™
09-30-2023 01:19 AM
Iron lHorse
06-30-2015 11:47 PM
moondeaux
09-25-2009 06:18 PM
rixida
01-07-2007 08:16 PM
KeithB
09-11-2006 02:03 AM
Quick Reply: Removing steering bearing cups from Deuce
