Oil lines changed to braided?
Old 01-08-2014, 06:18 AM
Ink83's Avatar
Ink83
Ink83 is offline
Has anyone changed there hard line to braided hose on their oil lines to the tank? Curious if so what fittings are needed? On whatever softail models that are the same as my 07 train.
I'd like to some how black them out, wether painting them would be an easier option I don't know. Any one painted theirs? Any help would be appreciated!
Old 01-08-2014, 07:10 AM
Ink83's Avatar
Ink83
Ink83 is offline
No body at all? I've been googling it but can't find anyone that's done it...surely some ones had a go at it
Old 01-08-2014, 07:28 AM
24v's Avatar
24v
24v is offline
Old 01-08-2014, 07:45 AM
Ink83's Avatar
Ink83
Ink83 is offline
[QUOTE="24v;12175264"]Here is what I have found so far. https://www.hdforums.com/forum/11623612-post26.html[/QUOTE
Thanks 24v! Greatly appreciated. That gives me an idea on the fittings needed at the engine end. It does look good.....oh and the black push rod tubes, why did I have to look at that! Haha
Old 01-08-2014, 04:07 PM
tbonetony06's Avatar
tbonetony06
tbonetony06 is offline
I am interested in this thread and will be following it. I want to change out the oil lines I have going to and from my oil cooler and I want to bling those out too, if I can.
Old 01-08-2014, 05:46 PM
bauer4567's Avatar
bauer4567
bauer4567 is offline
Hey there. This might sound a little cheesy, but testors model paint is what I used on mine. Covers completely, dries itself to a clean finish without brush marks and has helped up without a wrinkle or chip for the past year. I also did every bolt I could find with the testors paint in the little glass jars or they also make testors paint sticks which match the color and finish of the glass jar paint.
I started just doing a few bolts, but once I realized how well the stuff holds up, I figured it would try it on those oil lines too. Good luck!
Old 01-08-2014, 06:20 PM
Ink83's Avatar
Ink83
Ink83 is offline
Originally Posted by bauer4567
Hey there. This might sound a little cheesy, but testors model paint is what I used on mine. Covers completely, dries itself to a clean finish without brush marks and has helped up without a wrinkle or chip for the past year. I also did every bolt I could find with the testors paint in the little glass jars or they also make testors paint sticks which match the color and finish of the glass jar paint. I started just doing a few bolts, but once I realized how well the stuff holds up, I figured it would try it on those oil lines too. Good luck!
Any pics of the lines you painted? Did you have to rough up the chrome first?
Old 01-08-2014, 06:29 PM
Ink83's Avatar
Ink83
Ink83 is offline
I have a friend who owns a parts distributor store and distributes AeroFlow so when I can work out what fittings I'll need, Ill post up. Depending if I get time before the bike goes in the shop to get a new front end next week too, as I'm thinking I might have to pull the lines off to be sure on all the fittings are correct and fit....we will get there
Old 01-08-2014, 07:17 PM
24v's Avatar
24v
24v is offline
I have used bbq paint in a spray can. Spray a little in the cap and use a brush to paint bolts. Never tried the lines though. Works great on bolt heads.
Old 01-08-2014, 08:45 PM
m i k e's Avatar
m i k e
m i k e is offline
i have painted mine w/ hi-temp paint so far 2 seasons no probs
i have also recently seen someone w/ wrapped oil lines which i thought was kewl
i think it was a breakout or rocker
i left the braided part to give a little contrast
Quick Reply: Oil lines changed to braided?
