Windshield bug remover
Old 12-28-2013 | 12:19 PM
flipbel's Avatar
flipbel
Default Windshield bug remover
Hello and happy holidays to everyone. I changed from a harley windshield to a memphis shade and I have a 16oz bottle of harley bug remover left over. Does anyone know or has used this on a memphis shade. Memphis shades are made of Lucite acrylic. Thanks in advance and have a safe and happy New Year.
Old 12-28-2013 | 12:51 PM
tbonetony06's Avatar
tbonetony06
I can't speak of what you ask but I can give you a tip for the best bug cleaner ever! Soap and warm water! I'm not being a smart *** either. 1st, make your solution up then put an entire towel down in the warm soapy water, semi ring it out then just lay it flat over your windshield, any windshield and let it sit on there for 5 minutes or so and soak. It softens the bugs up then they just wipe right off without scratching your windshield. Just make sure your rag or towel is really wet when wiping so that you don't drag the bug and bug guts all over your windshield. That is what scratches your windshield. I know this isn't what you asked for but I have seen people buy all kinds of stuff for their windshields when the best there is, is sitting right under their kitchen sink. The key is letting the warm, wet and soapy towel sit on there long enough to get down to the bug guts before wiping it off.
Old 12-28-2013 | 01:14 PM
Misbehaven's Avatar
Misbehaven
I agree with the above. After a long late spring ride my windshield is caked with bugs. A wet soapy towel laid over the windshield while I chill with a beer does the trick. I also clean my windshield with lemon pledge it helps to keep the bugs from sticking so bad and it acts sort of like rain-x.
Old 01-02-2014 | 09:52 PM
cmancini26's Avatar
cmancini26
Fabric dryer sheet. Wet sheet with water and clean windshield. Wipe off white residue left behind. The stuff they use in the sheets takes bugs right off
Old 01-02-2014 | 10:08 PM
wyndnface's Avatar
wyndnface
Ditto with the warm soapy towel soak
Old 01-03-2014 | 01:17 AM
DK Custom's Avatar
DK Custom
Platinum Sponsor
I've used hot wet towels, bugslide and hydrogen peroxide...all of them work pretty well...never used a fabric dryer sheet, gonna have to give that a try.
__________________
TRICK!?!? From Harley- See Here
OR
TREAT from DK Custom Products ~ 10% Flash Savings on All Air Cleaners, use Code: Clean10
DKCustomProducts.com
Call/Text: 662-252-8828
Old 01-03-2014 | 12:50 PM
streeteagle's Avatar
streeteagle
I usually do the warm, wet towel thing too, but for quick bug removal the Clearview Shields cleaner & polish using a microfiber towel works great.
Old 01-03-2014 | 01:06 PM
lemonade_07flstc's Avatar
lemonade_07flstc
I do the same thing, it does help the bugs from initially sticking so not as many to clean off, and smells good to, lol. I use the warm soapy water also, nothing better and doesn't cost you hardly anything.
Old 01-03-2014 | 07:46 PM
jm35ny's Avatar
jm35ny
I like to put rain x on first, maybe once a month. Then when it' get dirty Seems like the bugs come off much easier. I've always used a warm soapy towel too for bug removal
Old 01-03-2014 | 08:00 PM
Jim Kraft's Avatar
Jim Kraft
I use Sprayway glass cleaner on my HD windshield. I use to use lemon Pledge, but they changed their formula and it just smears. Sprayway is the best I have found and leaves the windshield crystal clear.
Quick Reply: Windshield bug remover
