Breakout exhaust suggestions?
#112
You can buy them here.
http://www.revzilla.com/search?query...20arlen%20ness
#113
#114
I talked to Revzilla, Arlen Ness (the company not him personally), and MagnaFlow. Revzilla was unsure and checking into it as including the Breakout may have been an oversight and didn't appear on their spec sheet. Arlen Ness said they were unaware of any fitment issues and they should work on all, including the Breakout and Rocker. Wanting confirmation, I called MagnaFlow and spoke with the gentleman heading the project. He informed me that the Ness-Comp (longer one) is listed as not being compatible with the Breakout. The F-Bomb does not have any known issues with the Breakout, but is presently listed as incompatible with the Rocker. He did say that he wasn't sure if this had been finally tested to confirm or if it was just certain years.
Sounds like it's a little bit of a gamble, but I'm ordering an F-Bomb. Hopefully all goes smoothly as it should be an awesome pipe.
#115
Thanks for mentioning what they said to you about the Fbomb fitting the rocker.
If they are saying the Fbomb fits the breakout then it has to fit the rocker. The mounting points for both bikes are in the same exact spots and the swing arms are the same width.
I'm pretty sure the oil lines on both bikes are in approximately the same spot. I don't think oil lines would come into play when mounting this type of exhaust anyway.
If anyone hears anything about these fitting the rocker let me/us know.
There are a bunch of rocker guys around here that I'm sure would love to rock these.
#116
#118
#119
#120
Those are Performance Machine mid controls for softails.
You need to get an open primary on the other side for their left side mid controls to work.
Oops. I just realized you were asking about the passenger pegs and not the mid controls. HD sells a kit with a small bracket that allows you to move the passenger peg up or down about an inch.
Hard to see in that pic if they used it or not.
