removed the baffles now backfiring
Old 03-15-2007 | 07:21 PM
revhoot's Avatar
revhoot
Default removed the baffles now backfiring
I removed my baffles on my se IIslip-ons, and now I have a terrible backfire everytime i shift. I am wondering if i can adjust something to make it sound a little better? I like it louder, but i don't want to wreck something. should i put them back on, or live with the backfiring?
Old 03-15-2007 | 07:23 PM
06hog's Avatar
06hog
Default RE: removed the baffles now backfiring
I picked up a PC III and fine dyno tuned mine and runs like a charm. I have V&H BSS w/o baffles and love it. No more back firing at all...
Old 03-15-2007 | 09:19 PM
Aces N Eights
Guest
Posts: n/a
When you purchased the SEs, did you get the download, SERT orPCIII? Stock tuning will cause backfiring as there is no back pressure without the baffles. If you did not purchase any of the above then I suggest doing so as it will eliminate almost all backfiring. Another reason you didn't have it prior to removing the baffles is the baffles tend to muffle it to the point of almost inaudible.
I know this as a result of purchasing the SEs, A/Cand download. Removed the baffles from the SEs with minimal backfiring. I also purchased the Rush SOs and can hear some BFing under deceleration but it is minimal and I can live with it.
Hope this helps,
07HC
Old 03-15-2007 | 09:29 PM
DanDeuce's Avatar
DanDeuce
Check the clamps between your pipes and the SE slippons . I mentioned popping to the tech when new and they tightened them up , supposedly . A month or two later I put on my V&H Pro-Pipe , I loosened the mounting bolts to the frame and not the clamps . I pulled the mufflers off , theywere loose as could be , could have fell off !
Old 03-15-2007 | 09:32 PM
Terry TK's Avatar
Terry TK
Big Kahuna HDF Member
Your AFR (Air Fuel Ratio) has changed due to the lack of back pressure (free flowing pipes). You will have to have your bike rejetted (carb) or if you are EFI you will need a different download, PCIII or SERT to adjust your AFR.
Old 03-16-2007 | 03:55 PM
burgies08ultra's Avatar
burgies08ultra
i know of a couple of guys who have put an eyebolt where the screw that holds the old baffles in. and it works pretty well to give it a little back pressure...db
Old 03-16-2007 | 04:20 PM
Oldtimer of NM's Avatar
Oldtimer of NM
The 2 main problems that cause backfiring are bad mixture and air leaking into the exhaust system. SInce you have been working on the pipes, you mihgt have both problems.
Old 03-16-2007 | 05:02 PM
djzoo's Avatar
djzoo
i am installing V&H big radius pipes with baffles w/ PCIII, if i remove the baffles will i have the same problem? Or can I just select a different map for the bike if it does occure?
Old 03-16-2007 | 06:03 PM
revhoot's Avatar
revhoot
thanks guys.... i should prolly get a pcIII... just gotta save a little $$$$ first... are those hard to install? something a guy can do himself?
Old 03-17-2007 | 12:50 AM
06hog's Avatar
06hog
You can install and download a PC III the right map for your bike and its accessories in less than 20 mins with a computer. Easy as anything. Will take care of all AFR issues you have, you can run with or without baffles then also.
