My deluxe build slowly
The hot rod is also one of my ongoing projects. Its a 1930 model A sedan we chopped 6 inches and channeled 4. It has a 1953 276 (baby) Desoto hemi .40 over 4x2 intake hand ground cam turbo 350 trans with an adapter plate 1935 ford axle along with the wide five wheels on the back with adapters on a 9 inch custom built frame with air bags in the rear and some fatty whites! Here are a few pics..If they do not belong on here please delete.
Attachment 347908
Attachment 347911
Attachment 347912
Attachment 347913
Attachment 347915
Attachment 347908
Attachment 347911
Attachment 347912
Attachment 347913
Attachment 347915
The Deluxe looks great but I am really digging the ratrod myself. Keep up the great work and keep us posted on both rides
It was not hard at all I drilled a hole in the top of the bracket so I could hide the wires in behind everything. I took a small drill bit and drilled the connector out where the stock tag light is cut the power wire that is tied into the same connector as close the connector then I used a crimp connector to tie power to the white wire on the tag bracket that went to the grey wire that you cut off the stock light. then I used a crimp connector with a hole in it and bolted it through th hole i drilled out the stock connector
Got home from work today the sun was out mid 50s so I pulled my bike out of the shop first time she has seen sun or daylight since the new wheel tank badges and softbrake relocate kit progressive drop in lowered the front 2 inches hope to have the back wheel in a few weeks or so.
