Old 02-13-2015, 02:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old 06-30-2014 | 02:23 PM
NAME CHANGE REQUIRED's Avatar
Originally Posted by 24v
Why not rewire the wires from the hand controls to the bar end signals? If this is not an option, then yes, you can wire them directly. There is an open plug down under the front of the tank on the right side of the bike. purple is signal, blue is running, and black is ground. Everything will still work in the hand controls.
Yeah, that was the first option that crossed my mind but I figured it would require another hole to route the hand control wires back into the bar, which I was trying to avoid. I'm not a talented mech so I'm trying to keep it as simple as possible.
  #902
Old 06-30-2014 | 03:07 PM
JimGnitecki's Avatar
JimGnitecki
JimG,you are missing the point, he isn't removing them, he is replacing them with a different type.
No, I understood what he is doing. But, the type he is replacing them with is probably not going to be accepted as legal in most jurisdictions. There are size, location, intensity, and DOT approval issues with many (maybe even most) of the aftermarket signal solutions.
Jim G
  #903
Old 06-30-2014 | 04:05 PM
24v's Avatar
24v
Originally Posted by NOFUKS2GIVE
I was hoping you would chime in 24v. Do you have any guidance here? When you removed your front signals did it throw a code or affect your rear signals?
Edit: You beat me to it.
First I don't have front signals anymore, and secondly I have LED's in the rear. Because of this I do get bcm codes, but they don't cause any issues. Also, the signal on the dash blinks twice as fast as usual, but the actual turn signals blink as normal.
There is a hole on the bars right under the hand controls to route the wires into, you could just feed the signal wires through the same hole, but run them to the bar end rather than towards the center of the bars.
  #904
Old 06-30-2014 | 08:39 PM
Jim G
Based on the average age of most HD riders I would assume that they either already did their due diligence, or they don't give a crap about the state regulations. I wouldn't assume otherwise until proven wrong.
  #905
Old 06-30-2014 | 08:47 PM
I think I can prevent the BCM codes by splicing in load resistors.
Right on man, thanks for the info. I'll give it a go after my bank account recovers. LA DOG talked me into buying a bunch of expensive **** for my motorcycle.
  #906
Old 06-30-2014 | 11:17 PM
HDthunderRB's Avatar
HDthunderRB
Those bar end signals really do clean up the front end
  #907
Old 06-30-2014 | 11:23 PM
asputin's Avatar
asputin
I moved my plate to the axle today.while I was at it I plasti dipped the struts..
Attached Thumbnails The Everything Breakout Thread-092.jpg   The Everything Breakout Thread-100.jpg   The Everything Breakout Thread-113.jpg   The Everything Breakout Thread-140.jpg   The Everything Breakout Thread-144.jpg
  #908
Old 06-30-2014 | 11:26 PM
asputin's Avatar
asputin
I couldnt put any more pics in that post
Attached Thumbnails The Everything Breakout Thread-153.jpg   The Everything Breakout Thread-164.jpg   The Everything Breakout Thread-160.jpg   The Everything Breakout Thread-150.jpg
  #909
Old 07-01-2014 | 06:28 AM
Firefighter0763's Avatar
Firefighter0763
Default Side mount plate
Originally Posted by Microdoted
for anyone curious.... took a few ideas from 24v and slightly modified. removed the license plate and rear turn signal extensions and bolted them straight up.
then got a kury curved & lighted license plate kit and swingarm mount. removed the LEDs and sent it off for powder coating. came out pretty damn good!
I have this same mount but havent figured out how to run / hide the light wire. Would you mind explaining to me how you did yours?
Pics would be awesome.
Thanks in advance.
  #910
Old 07-01-2014 | 09:05 AM
They really do. I'll post a follow-up once I have them installed.
