Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
• Seats
• Risers
• And much more!
#7012
#7013
#7014
^^ Cruisn you should touch base with Mchad re Arlen Ness Big Rotor Kit?
https://www.hdforums.com/forum/2018-...installed.html
cruisn (08-30-2019)
#7015
#7016
#7017
I have a dumb question about swapping wheels. If I have a Breakout with ABS, do I need all ABS bearings, or just 1 per wheel and the other side regular? I understand the ABS bearings are what triggers the ABS sensor, and that they are thicker than regular bearings, but are they used on both sides of the wheel, or just the side the sensor is on?
#7019
speed info for the ABS system.
#7020
Are there any differences at all (size-wise) between all the generations of Breakout wheels (10 spoke, Turbine, and 2018+), or do they all swap with each other freely? Would complete rears with pulley and rotor attached just swap between bikes without doing anything, or do you have to use different or additional spacers on any of them?
