Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
• Seats
• Risers
• And much more!
#513
#515
Tried this in another post and didn't fare so well so trying it here.
First harley and wanting to do some mods myself. Just ordered VH big radius 2-2, SE Heavy Breather and the FP3. Don't have the service manual yet.
I assume the ECM data port connector is under the seat somewhere and not near the ECM itself... which I understand is behind the rear fender and access requires removing the tire and fender?
I'm not clear on 02 sensors. I have to remove the rear wiring, attach to the pipe then re-run the wiring back? Assume this is because there is not room or enough slack in the harness to install the sensor without removing?
Videos don't show installs using torque wrenches. Not necessary?
Thanks. You guys have some unbelievable bikes...
#517
#518
#520
Need to pull my fuel tank soon. Going to relocate turn signals does anyone know the size of the cross over line? 1/4" or 3/8" ID I want to put in a quick disconnect! http://www.coyote-gear.com/quickdisconnects.html
