Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
• Seats
• Risers
• And much more!
#4911
If they don't need to come off, I wouldn't take them off. Maybe someone more experienced on them can comment though. I'm talking theoretically.
Jim G
#4912
#4913
I'm not sure that removing and re-torquing those pulley bolts is a great idea. The torque needs to be in a specific range to be tight enough to not get loose, but not so tight that you strip threads. The loosening and retightening affects the "real" torque being applied.
Jim G
Jim G
Yeah I have never removed sprockets or rotors either for any tire changes before.
#4915
FWIW guys, the service manual says that the pulley bolts cannot be reused.
They are cheap and the stealerships always seem to have them in stock. Buy a new set if you ever need to remove and reinstall/swap the pulley.
Having said that, I've never bothered to measure the bolts before/after being torqued into a wheel..... hhmmmmm... might be an interesting subject to check into...
#4916
Jim G
#4917
Blackline Tank Console Breakout 2016
Happy 4th of July everybody.
I want to change the console on my 2016 BO. Already checked the great instructions and part lists here. I just want to make sure it still works for the 2016 as well. Im asking because I tried to get the edge cut brake and clutch levers and they don't fit for 2016. Did anybody already change the console on a 2016 ? Or are the parts are still the same ?
Thanks
Mario
Thanks
Mario
#4918
Thanks
Mario
Thanks
Mario
#4919
Received 1,940 Likes
Thanks
Mario
Thanks
Mario
#4920
Thanks
Mario
Thanks
Mario
