Old 02-13-2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old 05-08-2015, 06:38 AM
helgi33's Avatar
helgi33
helgi33 is offline
Originally Posted by LA_Dog
I would contact Hillside Cycle www.hillsidecycle.com - one of the best sources for building current twin cam motors. I would be very concerned if your static compression really is 10.0:1 with the SE255 cams. do you know if the cams are earlier model with a 30 degree intake close or later model with 25 degree intake close? either one is only designed for lower compression like 9.3 to 9.5. You need a cam with an intake close of around 40 degrees with static compression of 10:1. You should also have specification from the SC manufacturer on optimal static compression.
You need to ask Darkhorse how they calculated the 10:1 - this is all basic mathematics- there is no room for guesswork with engine building, there is a calculation for everything especially figuring static and dynamic compression. there are better cams and you should definitely use something else, but you must be able to know your exact static compression first. Hillside Cycle can probably give you some friendly advice-
I would also contact Bob Woods at woods cams, and also T-Man cams (google search). They should know a good cam for your application and both of these cam makers are highly regarded- but again they need to know your static compression and probably some specs on the SC, and how you plan to ride the bike (town, drag strip, etc) - anyway call all three of these places.
My concern is if you fire this baby up you will have way too high of static / dynamic compression and the only way it will run without pinging is to seriously retard the timing. e.g. not much power. keep in mind the SE255 cams were made for low static compression. not a good idea to use them with 10:1 or higher.
Vrod forks sound nice but you can get the same good suspension with simply upgrading the springs to race tech and adding ricor dampers- a lot less work. see the sticky at the top of the Softail forum.
Good luck brother I can appreciate all of the work you are doing-
Hi LA_Dog
I apreciate all input on my project. I am traveling around South e
East Asia at the moment so not wifi available at all times...
I will contact the Cam companies when back in UKbut have looked at the details since I saw your post.
The H competion rods are only 0.010 longer than original so will take CR from 9.3 to about 9.46 so well within the 10:1 CR. I alreade rode the bike about 320 miles before I brought it to TTS performance and it was very fresh and lifely and no signs of detonations.. I have the power vision connected and the ET was around 235-240 cruising at 80-90mph which I think aint to bad..
The reason for Vrod front forks is not about performance... it is for the dual disc conversion.. attacment for calipers on both sides.. The Vrod forks are also 49mm but either 3/4" or 1" longer so am interested to see what effect it will have on looks and performance..
again apreciate your input on my project.. am bit in the dark on the whole thing and any input is apreciated..
After reading the whole 270 pages of this thread... then was hoping also to get comments from 24V and JimG as they both seem very knowledgable and active Breakout memebers.. :-)
Regards from Philippines..
  #2742
Old 05-08-2015, 07:59 AM
jgos929's Avatar
jgos929
jgos929 is offline
Be careful what you wish for. While jimG is a knowledgeable guy he'll knowledge you to death. 24v and LADog get right to the point.
  #2743
Old 05-08-2015, 08:06 AM
mseymour3's Avatar
mseymour3
mseymour3 is offline
Alright here's an update to my earlier post on the rear 68T pulley upgrade.
This was definitely worth the cost of sprocket, bolts and time to put it on.
Forgive my ignorance but on this sprocket change/upgrade what are the pros/cons and what else if anything did you have to change for it? Thanks.
Michael
  #2744
Old 05-08-2015, 09:15 AM
LA_Dog's Avatar
LA_Dog
LA_Dog is offline
Originally Posted by Woody.
#cvo #breakout
Found this one on Facebook yesterday. These cvo rims look cooler without the brakedisc on the exhaust-side of the rear-wheel.
Yep- Performance Machine (and probably some other companies) make a setup that combines the rear brake disc and caliper with the right side pulley. this requires either welding mounting tabs for the brake caliper on the right side of swingarm, or buying the aftermarket swingarm as well.
Very trick setup for any bike- definitely a "visual only" upgrade albeit a nice one.
I like those mirrors- would love a set in black. Thunderbike really does a nice job with modifications to the Breakout.
BTW welcome to the forums!
  #2745
Old 05-08-2015, 09:31 AM
LA_Dog's Avatar
LA_Dog
LA_Dog is offline
Originally Posted by helgi33
Hi LA_Dog
ok that's sounding better. if your CR is really only 9.4 then yes you'll still be safe. I give you my word though, if you ditch those cams, mill the heads a bit to raise compression to say 10.5:1, and get the right cam to go with it, you will **** yourself. you have a beast waiting to be unleashed. anyway, Hillside, Bob Woods, T-Man can all give you some advice on what to get. Also make sure your final quench is between 0.030 and 0.035. this is very important for optimal combustion. you calculate this by determining height of piston top in the bore (is it "zero" flush with the top of cylinder at TDC, or is it 0.010 down in the bore, etc). use this number and add the thickness of your head gasket to it, to get your quench. For example, if your head gasket is .030 and your piston sits 0.010 down in the cylinder bore at top dead center, your final quench is 0.040. You can reduce the quench by using a thinner cylinder base gasket as well, for example a .010 base gasket will make the piston sit 0.010 higher versus a 0.020 base gasket. You can also have the cylinders shaved a bit shorter if needed. Whenever I build a motor I always set up the pistons to be "zero deck" so the top of piston is flush with top of cylinder at TDC. That way I can control the quench with just the head gasket. Makes it easier to fine tune your static CR up or down a bit, if needed, by using a thinner or thicker head gasket.
Anyway- short of it is, know your EXACT static compression, use an optimal quench of 0.030-0.035, and choose a better cam designed for that compression and your riding style.
When choosing a performance cam you must always set your static compression to the "optimal" range for the cam. Every cam is designed for an ideal static compression so it results in an optimal dynamic compression. Woods, T-Man and many other cam makers always specify optimal static compression range for their cams. For example, the T-Man 625 Evo cam is designed for an optimal 10.5 static CR and will result in a dynamic compression of 9.5.
The VROD dual disc setup will be pretty trick- I see your point. You will also get better cornering clearance with the 1" longer fork. You can set your "fork sag" lower if needed by shortening the preload spacers. Although I think you'll be happy with the added 1" and visually you can't tell the diff. I would still get the race tech 1.0kg springs and Ricor dampers though, they work wickedly well and will fit the VROD forks. Call Race Tech and Ricor to order the right parts. you'll find the installation rather easy.
  #2746
Old 05-08-2015, 09:38 AM
LA_Dog's Avatar
LA_Dog
LA_Dog is offline
Are you kidding- I'm a rambling post *****. look I already got 4 or 5 posts on this page alone and it's only 7:30am.. LOL
  #2747
Old 05-08-2015, 09:43 AM
LA_Dog's Avatar
LA_Dog
LA_Dog is offline
Michael
No worries- that's what these forums are for, asking questions. all you need is:
1. the 40444-07 68T sportster sprocket from HD
2. the shorter sportster bolts and washers from HD
3. remove rear wheel, remove stock sprocket and put on the new sprocket, tighten bolts to proper TQ (60 ft lbs on first tighten, then loosen each bolt a bit and final tighten to 77 ft-lbs)
4. put wheel back on, align wheel, set belt tension, tighten axle nut to 95 ft-lbs, go ride and enjoy!
[EDIT] 5. whoops almost forgot, your speedo will be off by 3% due to final drive ratio change.
You'll need a PV2, SERT, or have dealer change the speedometer calibration number to 2262 pulses/km. If that is still slightly off then use 2232.
  #2748
Old 05-08-2015, 10:01 AM
mseymour3's Avatar
mseymour3
Awesome. Thanks.
Michael
  #2749
Old 05-08-2015, 05:38 PM
LA_Dog's Avatar
LA_Dog
LA_Dog is offline
I got one of the little "bling" WilleG emblems for the custom backrest. nothing special just wanted to post another gratuitous photo of the bike.. ;p
BTW I found a pair of those mirrors in Black, the ones on the Thunderbike CVO Breakout a few posts up. They are the Rizoma Circuit 851 mirrors, about $130 each.
Got the pair on ebay for $85 shipped. figured it was worth a gamble at that price..
  #2750
Old 05-08-2015, 06:07 PM
JemmyPaeg's Avatar
JemmyPaeg
JemmyPaeg is offline
Originally Posted by cdonis
Procharger,with the stock crank?
Never heard of any reliability issues due to running a stock crank with a procharger setup with mild boost?
That being said, no, the engine will be getting a overhaul, I want this thing to be reliable. After playing with forced induction on my car I'll never go back.
Quick Reply: The Everything Breakout Thread
