Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
• Seats
• Risers
• And much more!
#2641
i get up to 280 riding in town on a 80+ degree day on the stop / go stuff. running quite a bit of timing advance though. engine temp management only comes on at a stop or very slow cruise, mine is set to come on at 140c and off at 135c. have not had it come on yet though.
Open road temps at speed should of course be lower like 250/240/230 due to air cooling of motor.
I have to double check, but I think those are the same temp's I'm at as well, with tune #6/358. It was 70F here in Jersey yesterday - cool, sunny & breezy. A great day. I was just tooling around town, not stop-and-go traffic, and not out on the highway either. I rode the bike in much hotter weather last summer & never experienced this once.
I think the bike is running hotter now than it did a few days ago - when I first loaded #6/358 and went for that 5 hour ride, lol....
Is it possible that the bike's computer is tweaking the tune?
#2642
My bike was running very hot last season after Stage 1 (fp3, big radius 2:1, heavy breather). I saw >290 at least once in stop and go in 85 degrees and it was frequently running >265. This is oil temp at the digi dipstick.
This season, the hottest I've seen is 265 in 30 minutes of almost standstill traffic. Since I got my 1k service, the I haven't seen over 250. I'm keeping a close eye on it.
#2643
for the open loop values of AFR the ECM is not changing VE's at all and is doing it's best to achieve the richer AFR table values (the ones not in bold, under 14.2)
I'm working on an open loop AFR map right now- tested it out today and it ran well but saw a bit of excessive knock events under load (WOT, 3/4 roll ons etc). work in progress..
try the V9 / 358 I like it the best- won't change the engine temp any though- these bikes do run hot but shouldn't present any real problems.
for a test you could edit the AFR table and change the AFR values richer in idle / cruise. I'll post up a modified V6 shortly. run it and see how it affects throttle and engine temp in town. you can copy / paste the AFR table to the V9 tune as well.
#2644
...cool, sounds interesting.
I'm not really too concerned about all this. I was really just caught a little off guard when the EITMS kicked in. I wasn't too far from home - where my Power Vision was - so I headed back & plugged it in to see what the temp was.
It just made me curious about what temp range is considered "normal", ya know? Naturally, the owners & shop manuals say nothing about what's normal, lol...
#2645
#2646
#2647
#2648
FYI- the Free Shipping special on orders over $149 at Surdyke.com ends May 5th. So if you wanna buy the 40444-07 68T Sportster sprocket better get on it! I have not found it for a better price anywhere else, except for a couple of beat-up ones on fleabay.
