Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
• Seats
• Risers
• And much more!
#2071
[QUOTE=liamw76;13729708]
Here a a couple of pics that I took yesterday. I can get a closer shot for you later if you need it. I bought both the swing arm mount and the axle mount because I was unsure which I would want to use. Both are quality parts. I ended up using the axle mount so I could use a swing arm bag.
Just installed mine today. They are from topdownproducts.com. I've got the rotoplate on the left and this on the right. I also have them on the front. I bought the harley axle bolt covers but going to take them back. You have to remove the rear axle to install those. The topdownproducts bolt covers installs without removing the rear axle.
[IMG]https://cimg7.ibsrv.net/gimg/www.hdforums.com-vbulletin/2000x1
looking good. Got any pics of the roto plate install?
#2072
V&H Straightshots HS ONLY..?
As my AN Big Sucker appears to be lost in the post, can anyone tell me if there is a downside/problem with fitting the slip-ons alone for now (max 2 months) until a replacement air cleaner is delivered? (what does the "HS" stand for, btw?)
On a completely separate note, I just did 80Km with the new Danny Gray reduced reach seat fitted and that is my problem solved - absolutely fabulous and worth every cent.
No handle bar/cable change required. Slightly disappointed with the unbelievably crappy zinc plated washer that is supplied for the rear retaining bolt, but that's easily changed.
Just need the matching ***** pad now to stop the Mrs. moaning.
#2074
#2075
I had mine go over right in my garage. I'd just rode in, shut it off and set the stand, and then the bike moved slightly and the stand kicked out. I caught it, but it's not something I wanted to repeat, so IO;m very careful to make sure it's locked nowadays. I was hoping that the No Toil upgrade would work on the Breakout, but they only mention FL's.
#2076
So, is there a longer and mor forward leaning stand than can replace the stock one?
#2078
Thanks. The tail light lenses are from Hawglenses.com. The tail light housings are powder coated stock housings. As far as the bolts go, I just cleaned them very well and used some Krylon flat black spray paint. Once installed I just used a small paint brush to coat any paint removed from the wrench.
#2080
Michael
