Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
• Seats
• Risers
• And much more!
#161
Carbon Raptor is the name of a company that makes the coating I was talking about. It's thin and very durable so that your fork tubes can go into the wider part of the fork without scratching or messing up the seals. I liked it because most people don't do it, they just leave the tubes undone. And were not most people!
#162
#163
#164
#165
Also interested in how these change the look of the controls up front- I would love a side-view of how they look on the Breakout. And did you have to do anything with the wiring? I vaguely remember something about "SpacerJim's" spacers being OK with the 1", but I thought they said 1.5" was the absolute max reach for the cables without changing.
#166
LEDs and Shotgun Shocks
Those LED's look great. I am in the middle of a build on my new Breakout and am waiting for my ShotgunShock to arrive. I am looking at setting up LED's as well on my BO. I noticed that you mounted LEDs under the rear fender. If you don't mind sharing what LED's you used and how much space is there between the tire and fender when the wheel is fully slammed. I take it that there is no issues with rubbing the LED's off? Did you put one set on each side of the inner fender? Is the front done as well?
That green looks great with that gold metal flake.
#167
24v, I don't remember, that was awhile ago. I know there are some local people who do it, just Google it for So. Cal..
I hear you Nostradamus, but Rome wasn't built in one day. I'm not done yet! Thanks for input, I appreciate it!
Custom Dynamics makes the LED's, no problem with them being in the way when slammed. They are on both sides of back fender. The front break caliper has an oval disk attached that shines the lights all the way around the rim, very cool. There is also a kit for the break and running lights, it's a strip of LEDs that go across and just under the top of the fender, it can also be turn signals but I didn't use it for that.
#168
Your BO is a beauty! Can you also post a pic of the left side of the bike to see how it looks like?
#169
Hey BroTim, I was wondering if you got your intake from Wimmer? It looks like one and if you said in an earlier post, I didn't see it. The reason I asked is I have been looking at them as well. I luv the look of the two hanging pistons. I have been debating on which one to go with. Any information would be great. Not sure since I have a CVO with throttle by wire if the same setup would work.
#170
