Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
• Seats
• Risers
• And much more!
#1331
#1332
#1333
#1334
Interesting because RSD is a high quality product. This is the first I've heard of this with the clarity line. If it cracked or leaked, I would question the install first...possibly over tightening the screws or not seating the gasket correctly.
I will do a little research because I've been leaning towards the clarity cam cover.
#1335
[QUOTE=Goldsgym;13264676]
Uh, take a closer look. That belt is less than 1 inch wide (it's a metric measurement - 24 mm I think). See the edge of the tire beyond the printing in the sidewall? That's less than 1/8 inch between the tire and the belt. Some might call that "plenty of room", but I would not. Harley swing arms are not absolutely rigid under side loads.
Jim G
Jim G
#1336
[QUOTE=JimGnitecki;13265147]
Jim G
uh, I respectively disagree
I think it looks more like 3/8" on the 250.
24vt
please chime in.
Jim G
24vt
please chime in.
#1337
#1338
Received 1,940 Likes
Jim G
I'm certainly no HD tech but if the movement allowed a gap between the tire's leading edge and belt, of even 1/8", to close, not absolutely rigid would be a bit of an understatement no ?
Jim G
#1339
Everything is good so far. I haven't heard anything otherwise but I'll take a look at that thread you posted. I like them a lot and might get the clarity covers for the top of the motor as well.
#1340
Don't mind Jim, he's an enginerd. I mean you may have a problem under a side load, you know, like a Mac Truck hitting you or something.
