Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
• Seats
• Risers
• And much more!
#1071
It looks great! The reason I asked if you had ABS is because the Harley one only fits bikes without ABS..... I have a 2014 as well so thats why I asked. I'm assuming it comes primed ready for paint?
#1072
On the Thunderbike website it says it comes undrilled and unpainted. I would assume unpainted means unprimed as well.
#1073
#1076
I'm not sure. I know the 2013's abs was an option so maybe they just say with abs to make it known that it will work for both. When I look at it on my bike I don't think it matters with abs or not.
#1078
Is anyone using a TTS Mastertune on their Breakout? I was told this would be the best bet for my bike but wanted to get some opinions here. I searched the thread a little bit but didn't come up with much info. I'm going to imagine Harley has the cables to plug into the TTS and the Bike but any info would help
Or is it this one?
Or is it this one?
#1079
http://www.amazon.com/TTS-MasterTune...tts+mastertune
Or is it this one?
http://www.amazon.com/TTS-Master-Tun...tts+mastertune
Or is it this one?
Hope this helps
P/N 2000008 is a single tuner kit
P/N 2000011A cable kit
I am still trying to find the correct Kuryakyn part number for the cable kit as some say its 9227 & others say 9229
the supplier I am looking to order my tuner from uses the Kuryakyn part numbers & that's what makes it a little difficult for me
regards
Rod
#1080
Did you powdercoat your rear tail light? I want to do it but was told by the dealer that by removing the LEDs from the casing, it would break the waterproofing seal and it will fail when it rains. (It rains pretty heavily where I'm located)
This is holding me back from powdercoating the fender struts too.
