Racing Idle, Gauges Going Out, and Check Engine Light
Hi everyone,
Im hoping someone can help me with this issue. It started about 3 months ago but has only really become worse in the last couple of weeks.
I have an '03 Deuce with a little over 30K on the odometer which I bought used in March. This is the only issue I have had with the bike so far so I feel pretty lucky
About 3 months ago I would find that my idle would get stuck so that when I pulled the clutch in the RPM's would race. If I would slightly engage the clutch it would drop back to normal.
About 1 month ago it started getting worse by having the check engine light come and my gauges going out. The speedometer would either drop to 0 or it would freeze at whatever speed I was at and the check engine light would come on. When this happens its only for a few seconds and then everything goes back to normal.
Last week it changed and now I am having an occasional rough idle after the gauges come back on and once my bike has died when I pulled the clutch in.
It hasn't died since but I am still having all the other issues.
Ive checked the codes and from what I can see everything says CLR next to it so it doesn't appear to be keeping any codes in memory.
Ill take it to a shop soon if I need to but I'm hoping someone here might have an idea about what this is.
I changed the fuel check valve and hose about 2 months ago but this issue started before that. I haven't done any other work to bike since I bought it.
Thanks for the help
Thanks for the help
