samson fishtail exhaust performance
Old 12-04-2013 | 07:09 PM
HD2009deluxe's Avatar
HD2009deluxe
2nd Gear
Default samson fishtail exhaust performance
Hi guys, haven't seen many posts on this subject so I would love any comments or feedback.
I recently had my 2009 deluxe 96ci fitted with 204 se cams, big sucker arlen ness air filter and screaming eagle tuner running fishtail exhausts 28.5".
had it dyno tuned the other day and the numbers came back terrible. 75 hps and 83 fp torque.
Ive had 5 friends had the same gear installed on softail customs same set up but different exhaust and their numbers were identical 93 hps and 104 torque. all had identical exhausts big radius vance and hines. these pipes are notorious for not giving the bike the any chance at maximum output as say compared to 2 into 1 pipes. they all used the same dyno tuner.
what surprised me that as even as bad as the big radius are my fishtails were even worse. Im off by almost 20 horsepower and even more torque.
I never expected big horsepower and its not what Im going for just a little quicker and responsive than stock but this is ridiculous. now Im compromising looks for performance.
anyone else had same issues and done something about. thanks
Old 12-04-2013 | 07:16 PM
pipeyeti's Avatar
pipeyeti
Long pipes are usually the worst performing pipes.
Old 12-04-2013 | 07:52 PM
Galli928's Avatar
Galli928
That's a huge drop in just a different 2-2 exhaust system, long fishtails or not Seems like there has to be something else contributing to the low dyno numbers. What do I know though?
Old 12-04-2013 | 08:11 PM
Cembo's Avatar
Cembo
Not sure if the numbers are that terrible, but I would expect more since you have cams too. I have a 2013 Deluxe (103ci), Stage 1 - SE Heavy Breather, SE Pro Tuner and Freedom Performance 36' True Dual Fishtails. Dyno tuned - 74HP and 95fp. He specifically advised for the Freedom Performance and against the Samson as his experience was usually a loss in output with them. My mechanic said that I could expect hitting 100HP/100fp torque with good cams.
Old 12-04-2013 | 08:28 PM
HD2009deluxe
2nd Gear
just spoke to the dyno guy and he believes that Ive lost power due to back pipe that turns to the other side of bike and goes up and down over the primary. also the fishtail ends being thin opens all adds to the problem.
does that sound right to you?
Old 12-04-2013 | 08:36 PM
Cembo's Avatar
Cembo
As many on this forum will tell you, fishtails are probably the most restrictive pipes you can put on your bike and 2-1 will get you the best numbers. So in general, the statement is probably correct. However, you will find a lot of bikes here that have the same or a very similar setup like you and have been able to post higher numbers. Check the thread on Dyno numbers for softails. I am almost certain you will find the exact same setup posted and should be able to compare.
Old 12-04-2013 | 09:19 PM
Tailsfrommycrib's Avatar
Tailsfrommycrib
90 hp and 100 tq with 36 non baffled fishtails. The only thing I did was tmann tq cams and race tuner
Old 12-04-2013 | 09:25 PM
HD2009deluxe
2nd Gear
these are the numbers I was expecting. surely the longer pipes haven't made the output better.
Old 12-04-2013 | 11:58 PM
1 2 many's Avatar
1 2 many
Default hp #s
Does it really matter?? I am running a similar set up minus the cams and my bike runs great. yes you pay for results but in the end its just a cruser. Fishys are not great performance pipes....
Old 12-05-2013 | 08:51 AM
509Rider's Avatar
509Rider
Seems like you have something else wrong, my 06 with just Samson 39s s&s ac and Se race tuner put out 68 hp on the dyno.
Quick Reply: samson fishtail exhaust performance
