Rear Turn Signals as Brake Lights?
Anyone know of a kit to make the rear turn signals act as the brake light and turn signals? I want to entirely eliminate the bulky red light and plate holder on the bobtail fender, maybe even chop of a few inches off the fender behind the seat. Any help isappreciated, and pics if you got em!
RE: Rear Turn Signals as Brake Lights?
Just look around there are a number of them, Harley included who make them.
Not sure where I saw it but there are rework instructions for making the turn signals into running lights as well.
The other option is to get a different tailight like the LED version that Joker Machine and Harley make.
I didn't likethe big old light that came on mine either so I put the Harley Tri-Bar LED light on.
Its much nicer looking and brighter to boot.
This is it while its on, but hit thebrake and it gets evenbrighter.
The silver plate under it is something I fabbed up to support the tin foil plate the DMV gives you.
ORIGINAL: BlackBetty06
[/align]Auxiliary Running Light / Brake Light / Turn Signal Conversion Kit
Turn signal module adds an auxiliary brake light and running light function to your existing turn signals for auxiliary rear lighting. Easy-to-install, the kit simply plugs into your existing wiring harness. Red turn signal lenses are included. Meets DOT requirements.
69461-06A
Flat Lens Style
Fits all '96-later Softail® models and '97-later Touring models equipped with flat lens style turn signals. (Does not fit with Narrow Chrome Directional Bar P/N 68611-98.)
MSRP US $54.95
[/align]
ORIGINAL: djkolp
69461-06A
Flat Lens Style
MSRP US $54.95
[/align]
69461-06A
Flat Lens Style
MSRP US $54.95
[/align]
HD is the easiest way ... but the Kuryakyn ones actually pulse the turnsignals when breaking first. I like that idea. I have the HD ones but would go Kuyryakyn if I had to do it over again. there are other brands out there as well but they usually require you to cut and tap wires.
I think the Kuryayn are plug and play like the HD one.
ORIGINAL: clueless
http://www.kuryakyn.com/products.asp...ey&ci=2577
Have fun.
