I've searched and can't find your original "how to" on your stealth led front signals. Could you post the link?
thanks
search forum for "amazon led turn signals" and you'll find the posts from me with pics / parts info- I'll turn this into an individual thread later this evening.
Tonight I relocated my turn signals, I used Drag specialities 49mm brackets, no cutting of wires, I just pulled the wires through the bars relocated them plugged them straight in and away we went.
How did you move the signals without any wire cutting? I thought the wires were soldered into the controls and the signal passes through the 2 can bus wires.
I'm thinking that maybe the UK model could be different as mine has 2 plugs, one either side of the tank, all i did was move the tank back enough to get at the plugs, undone the the leavers and controls on the handle bars so to give me enough space to pull the wires through. my wires came straight out the back of the turn signal then down to the switch, so simple to do, took me less than an hour.
This is it the wire from the turn signal right down to under the tank, one of these each side, no cutting required.
