Unusual Shotgun Shock question
Hey guys, I currently ride a Street Bob. I really like the Softail Slim, and was ready to buy one, but dragged the boards too much on the test ride. I'm a bit of a "spirited" rider in the twisties.
My question is this: Has anyone used a shotgun shock to raise a Softail? Can it even be done? I'm just wondering if the normal setting for a shotgun shock is stock height, and the only adjustment is lower? Or can you raise it also?
Also, how is the ride and handling with it raised if you can do that?
Thanks
Crazy
Thanks
Crazy
There is no normal position for the SS it can be set wherever you want it and set on the fly. It has 5" of travel, usually when running around town I'm about 1" lower than stock, as soon as I hit the highway Iraise it up a bit close to stock height with a nice soft rebound. As soon as I hit the twisties it raise it up and stiffen the rebound to increase my cornering ability. There is a really detail write up on it in the suspension section that is worth checking out.
Edit to add link
https://www.hdforums.com/forum/air-s...-write-up.html
Edit to add link
Thanks
Crazy
Thanks
Crazy
Hit the twisties also. Keep the SS at full height and stiffen it a bit. Also moved the floorboards forward with halfmoons, installed Ricor Intimidators, set suspension sag correctly, and rarely drag now. Can not say enough how much better the ride is if you upgrade both front and rear suspensions rather then rear only. Despite this, not sure if a softail will be better in the twisties then a street bob.
Well, I just now read your write-up that Uncle Chester posted the link to. Fantastic job. I noticed that you also used the term "spirited" riding. It sounds like I have my answer.
My only concerns now are the need to remove the shock to drain the transmission, and the possible longevity of the unit. I tend to ride 8,000 to 10,000 miles a year, and keep a bike 5 to 7 years. Like I said before, I've got a lot to think about now.
I rarely do now unless I'm on a strange road and not familiar with the contours...
As for longevity, many have had theirs for years without issues, and they're doing R&D and making improvements all the time.
Besides, they come with a full lifetime warranty, and customer support, the likes of which you won't find anywhere.
Toolguy
09-23-2008 12:06 PM
