Clutch help!!!!!!
Clutch help!!!!!!
Have a 2006 deuce and put a set of hill country customs bar and cable kit on my bike have done other bikes previsouly and had no problems buton this one we got everything hooked up and adjusted where the clutch lever everything feels as it should and it changes gears fine but when we pull the lever the clutch will not disengage and crawls when trying to start we ve checked everything over and over and can not seem to find the problem has anyone had this problem before ??? any advice will be greatly appreciated
When i installed new
Cable it was at its longest length and I went to trying to adjust from there I had good feeling lever pressure but it just won't disengage I can put it in say first gear let out of the clutch with the engine
Not running and you can't
Push it. But the ramp and the 3 ***** on the coupler is right
And snap ring is in fine. The
Bike was working flawless before we put the new bars on
