Am I lookin at trouble?
Ok, I got my scooter to the dealership for the 8* to 25* injector swap. They told me they’d be happy to do it, but their dyno was down, when I heard that I asked if I should just bring it back when they got their dyno up and was told that it wouldn’t make that big of a difference and I would be safe to run in that configuration until they could dyno it.
These guys have never steered me wrong before and they’re the reason that when I have work like this done, I ride the extra 50 miles to get to their shop.
Should I be worried that it won’t be dyno’d after the injector swap? What are the possible complications for not getting it dyno'd after the swap?
RE: Am I lookin at trouble?
Do you have any other engine mods? Are you running a SERT/PCIII? when I had mine swapped out they did the download only (no dyno) but immediately afterwards (within 50 miles) I went to the house and installed my V&H pipes, Ness AC, and the PCIII...I used a canned map and have had no problems due to the injector swap...I'm 2000 miles in w/the 25* injectors and I've never had my bike dyno'd simply because it's runninggreat as-is.
I agree with FXSTI Guy, If you are running a stock ECM with no aftermarket FI mods, you will be fine with the HD download. The 25* flow quite a bit more fuel than the 8* injectors. If your running an aftermarket FI and don't get it dynoed for the new injectors,you could be asking for trouble.
Buzzardbait
06-25-2008 11:54 AM
