Apes On My Breakout
#71
So I put the apes on today. Here is the parts list.
-Harley 12" wire extensions part# 69200034
-Harley Transmission Side Cover Gasket part# 36805-06
-Fat Boy 1.25" Risers
-Carlini 14" Pist Apes
-Carlini polyurethane riser bushings
-Magnum Shielding Cables and Brake Hose
-Clutch Cable part# 422212HE
-Throttle Cable part# 43196
-Idle Cable part# 44258
-Front Brake Hose part# 46148SW
Everything went together well. The brake line and cables are all very close in length but I wanted them that way. This is a temporary setup as the CVO Breakout risers are now on back order until Sept. 13th. I wanted to get the bars on cause the stock ones were hurting my back. Bike runs fine with no speedo and dummy lights too.
24V...I'm curious how tall you are for reference sake. Just wondering how well the bike might fit me. Thanks!
#73
You can, if you wish, go for a more integrated look with apes. You can lower the visual aspect of them while still enjoying the riding benefits higher apes provide by doing a 3" tank lift. One of the ways of doing this is to mount short risers on 10 degree forward angled riser bushings. This gives adequate clearance between the tank and speedo while keeping the speedo low to best obscure the tank gap, show at its most revealing angle here.
Its a matter of personal tastes, of course, but I think the lift gives the Breakout a line nicely suited to the look of the apes. Thats just me.
Do you happen to have any more pics of that bike from different angles? Nice looking bike!
#75
