Apes On My Breakout
Old 04-03-2014, 11:00 PM
24v's Avatar
24v
24v is offline
The boards look good on your bike because you have so much stuff on there already they blend right in. I worry with my bike being so plain, they may just stand out like a sore thumb.
  #52
Old 04-03-2014, 11:05 PM
CowboyBagger's Avatar
CowboyBagger
CowboyBagger is offline
Your bike looks really sharp, it's a long way from plain. I think black boards would look great!
Cowboy
  #53
Old 04-03-2014, 11:09 PM
24v's Avatar
24v
24v is offline
Thanks. I haven't ruled them out yet.
  #54
Old 06-04-2014, 07:53 PM
Rockett's Avatar
Rockett
Rockett is offline
Stage IV
Originally Posted by 24v
-Magnum Shielding Cables and Brake Hose
-Clutch Cable part# 422212HE (68 11/16")
-Throttle Cable part# 43196 (38 1/2")
-Idle Cable part# 44258 (38 3/4")
-Front Brake Hose part# 46148SW (48")
Yes, CVO risers.
Hey, i seen in another post u said the cables were very close, would you recommend going to the next size up in length?
  #55
Old 06-05-2014, 06:29 AM
24v's Avatar
24v
24v is offline
I guess that depends on how you like the cables. Mine fit pretty much perfect with no excess slack.
  #56
Old 07-25-2014, 12:15 AM
youraemoo's Avatar
youraemoo
youraemoo is offline
-Harley 12" wire extensions part# 69200034
-Harley Transmission Side Cover Gasket part# 36805-06
-Fat Boy 1.25" Risers
-Carlini 14" Pist Apes
-Carlini polyurethane riser bushings
Hey 24v
I have a questions regarding the setup
I have a 1.75 inch riser and the stock breakout speedometer
Would it still work? Or is it recommended to switch the CVO riser?
Also what is this part needed for
Is it part of the apes setup?
  #57
Old 07-25-2014, 05:50 AM
iconmaker's Avatar
iconmaker
iconmaker is offline
nice looking bike! ... i am thinking seriously about a breakout' ...but i'm in UK and apes are NOT very common over here or Europe from what i've witnessed definitely an American thing lol
drag bars all the way for me ... BUT great bike all the same my friend.
keep up the good work i'm hooked on this thread
  #58
Old 07-25-2014, 06:22 AM
24v's Avatar
24v
24v is offline
Originally Posted by youraemoo
Hey 24v
The stock 1.25" risers will work fine with this setup except you may want some cables that are 2-4" longer as the stock risers are taller. That is also the reason I di not keep them. I don't like the way apes look with tall risers.
The trans cover gasket is because you need to open that cover to replace the clutch cable, so you need a new gasket when you put it back on.
  #59
Old 07-25-2014, 06:23 AM
24v's Avatar
24v
24v is offline
For me it was more about function. The bike is so much more comfortable to ride with the apes.
  #60
Old 07-25-2014, 12:10 PM
iconmaker's Avatar
iconmaker
i must try one with apes! ... i've always thought that apes look soooo uncomfortable ....dont your arms ache???
Quick Reply: Apes On My Breakout
