Any advantage in switching to a 250 rear tire from a 240?
The 250 will look fuller and fatter than the 240. Double check with this, but it should fit your stock fender. Tight, but that will make it look NICE. It's a subtle change, but I like the look of a 250 vs a 240.
Disadvantage is everything to do with handling. It will offer a plusher ride due to the larger contact patch, but you have to lean harder into turns, etc. The larger contact patch also leaves you more prone to hydro planing in wet weather.
However, all in all. Any ride differences should be fairly negligible if you're used to a 240.
Thanks Doc J! At least the good news is that if I end up not liking the ride I can always go back to a 240 when I hit 20K. The other issue I have is that Metzeler is unlikely to have a tire for the 21" front until early part of 2014. How bad would it be if I had tires from different manufacturers with differing tread patterns? Safety issue?
flhrbill
12-09-2012 07:02 AM
