How to Adjust your Shotguns for Various Rides
This comes up so often and confuses so many people that I thought it needed it's own thread.
(searched, couldn't find anything specific)
I've been using the hell out of my shotguns and I still have trouble getting it adjusted the same way twice.
Things to know (which switches do what and WHY):
1. How to set up for Solo, LOW ride.
2. How to set up for Solo, COMFY ride.
3. How to set up for 2-Up, LOW ride
4. How to set up for 2-Up, COMFY ride.
5. How to set up for terrible roads (comfy might give too much 'porpoising')
6. How to set up for 'twisties'.
Please, share your wisdom with others.
I always just pump it all the way up (both switches up) until you're max height, then hold it for another 5 secs or so (at which point you should be pretty much max stiffness). then adjust you're desired rebound (left switch), then adjust height as wanted (right switch)
When out myself afterwards (stripped all the 2-up stuff off) and put it down so the rear pipes were about 2" off the road. Had it set perfect that I rarely scraped the tips.
Too bad I'll never be able to match those settings again...
Yea, It would be great if someone could incorporate something like the "e-level" system thats available for cars with air suspension.
I don't mind though, I'm constantly playing with it since I always raise it full up when going in and out of a gas station or parking lot. You should see some of the inclines to gas stations around Alberta. Pick up truck country forreal.
2-up might be 4 LEDs on the pump LED strip and 5 LEDs on the rebound strip.
I would LOVE to see a couple of handlebar-mounted LED strips (one for the pump and one for the preload). You could make note (for example) that firm solo might be one LED and the rebound LED strip would be (for example) 2 LEDs.
Yeah, I thought of this too. It would be the simplest, though tapping a line into both sides of that shock would be a very expensive proposition if things went wrong. Of course, one line is already exposed, so you could just Tee off that one - unless pressure does not stay on that line... Then, just one to drill...
I have mine down to a science, well, actually a simple count system. I go down the road holding both switches full up plus the 5 seconds. I then give each switch 2 flicks down, 1 at a time, each. That pretty much gets me down the road on a cloud. That is solo and I weigh 225. 2 up? I can't help you there. The extent of my 2 up riding is from the bar to my house.... and then back! Thats all I gotta say bout that!!!
